M7300/M5300 Mobile Band ID
K9ROD
Boerne, Texas
Is there a way to determine the band/frequency range from the model/serial numbers found on the stickers for these radios? ie: 700/800 or just 800 Thanks, Rod
merlin
DN32su
FCC ID will get you in the ball park. Halls electronics with the product code, you can see what shows up on matrics for the various builds.
These are dual band radios if I recall correctly.
merlin
DN32su
OK, only single band, VHF,,UHF,, or 700/800 Mhz.
What comes up selecting XG-75 in RPM for band splits:
136-174 378-470 764-870
From a manual:
73s
  • XG-75bands.txt
Radioman96p71
The M5300 and M7300 are both the same hardware and will both have the same radio part number (RU-144750-061) but the M5300 is 800MHz only, the M7300 is dual band. This is a software (feature) limitation.
The M5300 part number begins with MAHK, the M7300 is MAMW.
Loopy1
Central Virginia
If you look at the "loadapp.txt" file contained in the more recent firmware packages, it contains a breakdown of the radio models and bands based on digits 3-6 in the radio serial number.
  • loadapp.txt
2154
Sometimes you can also google the model number and come across different states contracts and can cross-reference the model number-frequency off of that as well.
