sorry i should have said CH721 on a m7300 i’m wanting a cleaner install in my console like you can do with a motorola XTL or Apx and have the mic connected to the rear of the head it’s helps keep cords organized with a clean look…… i found at one time a cover for the ch721 mic port awhile back but lost the info……. and i’m sure they make a microphone that is available to use the rear ports but it’s just finding the odd stuff i’m sure
I’ve seen that mic connector cap somewhere too, but I haven’t remembered where yet either!!!
Perhaps they did make something, but it isn’t published in any of the docs I have. There are even diagrams showing all the places you plug stuff in and the only diagram with the Conxall mic connectors show them plugging into the front panel.
It really would be easy to make one, and if you found a dual PTT hand mic, you could wire up both aux inputs… one as PTT and the other as ALT PTT. Then you can have an alternate PTT set up for each system.
Part of the reason I’m not sure this exists is because Harris has been a bit lazy in the past with audio accessories… I have an HHC731 and there is a section in the manual about how to set up a headset and it involves adding resistors to a custom made wiring harness… So if something exists, it’s likely a custom job. I’d just find your favorite hand mic, and buy a mating pair of lemo connectors and either a 25 pin or 40 pin accessory connector and DIY.
-Brian
