Mac or Windows?
Flower Mound, TX
#1
I would like to get back into the scanner hobbie. I have a old RS Pro106 and would like to update to a Uniden SDS100. But I have moved on to the Apple world of computers.
Question : Should I get a old PC just to run my scanner software only or try to run a third party software on my Mac?
I never had to load software on my old PC, because someone else programmed my radio. I still have my PC in the closet.
kbod9633
Charlotte Tn
#3
I run proscan, ezscan and sentinel all using a program called crossover for Mac
You don’t have to have windows installed
PA
#4
Get a cheap netbook for programming. It's probably cheaper and less hassle than setting up Windows on a Mac and dealing with cross-platform driver quirks, etc.
Bronty
Amherst, NY
#5
All of the scanners software is very light, so you should be able to find a very reasonably priced laptop. They have deals on off lease and recycled corporate models.
https://m.newegg.com/productlist?keyword=refurbished hp laptop
If you really want to use your Mac, you can use VirtualBox for free (good option over VMware and parallels which add to the cost).
Sent from my iPhone using Tapatalk Pro
