Maco 5 element Beam?
n4yek
Cosby, Tennessee
If the antenna is mounted in the vertical orientation, and you do not have the antenna elements above the tower, the tower will interact with the antenna.
prcguy
No matter how high above the tower you put it, the mast or the coax hanging down between elements will interfere and cause pattern problems. That's just the way it is with a vertical beam antenna unless its end mounted.
prcguy
FKimble
Newnan, GA
Your can use a fiberglass mast to avoid metal in the antenna field, or you can use a side or rear end mount also to avoid metal in the pattern.
