Maco Y-Quad installation w sirio 1/2 wave ground plane on top?
n7lrg
Hey all, anyone ever heard of combining the two on one 30' tower? I'm thinking the base of the ground plane would have to be higher than the driven element of the yagi so it performs as designed. Thoughts?
prcguy
There are formulas for this but I don't know them. It would also depend on if the omni had ground radials or not. I would think a second antenna on the same band should be at least 1/2 wavelength apart vertically and you will probably have some pattern skewing even at that spacing. 1/2 wavelength would be the lowest part of the top antenna 18ft above the highest part of the lower antenna. A vertical with no ground radials would have the least affect but if you have 9ft ground radials on the omni I would want it a lot higher than the quad
n7lrg
Yeah, separation would be the issue. The sirio 1/2 wave I use has no radials. They will get their own mast and tower.
