Macom bml 161 67/72 with control head
claman5
New Port Richey, Fl.
Hello,
I need help with the Dip Switch Settings for the BML161 67/72 macom evc to a KRY1011632/14 control head. I have all the cables but feel intimidated with the Manual instructions. Can some please help me with the correct settings.
Thanks .
DisasterGuy
Maryland Shore
The DIP settings depend on several things including if you will be using ignition sense, radio model, etc. I will make the following assumptions: NOT using ignition sense, radio is NOT an MRK, charge rate is RAPID.
SW 1 OFF
SW 2 ON
SW 3 OFF
SW 4 OFF
SW 5 OFF
SW 6 ON
SW 7 ON
SW 8 OFF
claman5
Macom bml 161 67/72EVC with control head
Hello,
Yes I am "NOT using ignition sense, radio is NOT an MRK, charge rate is RAPID".
I set all the switches the way you suggested and the EVC power on the opt. speaker is controlled by the radio vol. control, the control head powers up with just a flash of pad and screen lights. I have tried several other settings but nothing better than the first. HELP!
Thanks Bill
claman5
Yes, "the control head just flashes on for a second and then off?"
I can turn the EVC power off and on and each time the control head just flashes on for a second and then off again.
mm
oregon
Are you testing with a bench power supply or in your vehicle?
The charger requires at least 3 amps, with less than 3 amp supplied current I have seen the internal regulators sag and the unit shuts down.
Radioman96p71
One thing to take note, older revisions of the control head to EVC cable didn't short pins 12 and 13 together at the EVC end. Pin 13 is the RS485 Enable pin and needs to go to ground for the radio to be able to communicate with the control head. I've run into that a number of times on cables that don't have that pin and the control head will just briefly blink on and the radios display will either go blank, the second line will go blank, or it will go into a boot loop.
claman5
I am legally blind and will have some difficulties getting into the DB25 or the EVC to short pins 12 and 13 together at the EVC end of the 19B802554P20 cable that I got. Should the RPM1132864/2 cable have the pin shorted?? What will be my easiest fix?? I have two of these that I am working on.
Should I try a higher amp power supply first? That sounds easy!
Radioman96p71
The 19B802554P20 cable is the OLD style, and does NOT short the pin properly. You will need to either short the pin internally in the EVC (put a jumper between the pins on the solder side of the board) or get creative with installing a pin in the blank spot and wire-wrapping them together.
The late-model RPM 113 2864/2 cable does have pin 13 populated and connected to ground. It took a few hours beating my head on the desk before an email to Harris resolved it. He sent me a nice schematic of each cable and explained the difference. Apparently the first generations of the EVC shorted that pin internally, but later models left it as an option for the end user.
The power supply could be the issue, but not really likely. Unless the battery is rapid charging and pulling full load, the EVC power draw is minimal, and the control head pulls about 1.5amps with all the lights lit and full brightness.
One thing you can check, hook a speaker up to the EVC while you are testing and listen to it very closely as you dock the radio, you will actually hear the data bursts bleed into the audio PA. You will be able to hear 3-4 rapid burps of data as it tries to contact the control head, but no replies. A proper config will be generate a lot of data as the control head chats with the radio.
Hope that info helps. If i can find the PDF he sent me I will share it here, all I have is the printed copy. Usually its the opposite...
claman5
Thanks to everyone for all your help.
I will replace my old cable with two of the late-model RPM 113 2864/2 cables and see if my problem goes away.
DisasterGuy
Maryland Shore
The more I think back to the last Dual Enhanced Charger I installed, I had a similar issue with a cable that I fabricated myself using the schematic in the manual. I purchased a new cable from Harris and it worked flawlessly. I will have to dig around and see if I can find that old cable I made, short out the pins and see if it works.
Radioman96p71
The parts book i have (dated 06/2005) Uses the same RPM number as you specified. I do know that some of the older manuals (the MRK one falls in this category too i think) don't make mention of the RS485 Enable pin at all. Not sure what exact revision number the cutoff was but it appears to be right around the transition to the RPM 11 3264/2 numbering as all the cables like that i've seen have the pin there and shorted.
claman5
Hello to the Group,
I have received the latest-model RPM 113 2864/2 cable for my control head.
After hooking it up I had about 75% link with my control head. When it worked the radio screen said " *** DUAL*** ". other times the control head said "NET FAIL"
Will the EVC only work well with certain batteries?
