Mag Mount Rubber
samharding_21
I have a browning mag mount antenna on the roof of my truck; this mound has a rubber protector over the magnet. Would I get better reception by removing this cover? I am monitoring the railroad band 160-161MHz. I understand it may scratch the roof.
Sam
K7MEM
Swartz Creek, Michigan
It will scratch the roof whether you take off the rubber protector or not. The area under rubber protector may also discolor a bit. I had a mag mount on a rear spoiler once. When I finally removed it, the paint color difference was very noticeable. But I don't think it will provide any noticeable reception increase.
dlwtrunked
I have had a magnetic mounts (Larsen) on the roof of my 2006 Toyota Corolla with over 500,000 mile now. It has not made a single scratch on the roof (the front hood has lots of dings from road thrown stuff as expected for over 500,000 miles. In fact, when I take it off at the car wash, I have trouble figuring out exactly where I put the mag-mount (there is no pain fade either). This has been the case for my past cars also. Many here claim mag-mounts will always scratch a roof. It is simply *not always true* if one uses good mag-mounts and keep their roof clean.
but I would leave the rubber protector on, take if off when you regularly wash the car and be sure to clean the rubber protector also.
Ensnared
Waco, Texas
Sam
I have been hearing folks say this and that about whether or not a rubber boot on the bottom of a magnetic antenna will scratch paint. I can tell you without a shadow of a doubt, it does not. I have photographs.
I use have been using TRAM rubber-booted antennas on my Toyota for quite a while.
K7MEM
Well, I am glad you fared better then I did. I lived and worked in the Phoenix area for over 40 years. Between the heat (110-120 summer), dust, and blowing sand, the paint faded and scratched from mag mounts. And, I wasn't just my car. Other hams had the same problem in that area. So I wish you better luck than I have seen.
WA8ZTZ
S.E. MI
It will not affect your reception. Think about it... even without the protector you still do not have a direct metal to metal connection. There is a layer(s) of paint in between. The connection is capacitive. Have fun with your RR monitoring and worry about something else. :)
