MAG-One BPR40 in snow?
Seattle
#1
Has anyone used the Moto BPR40 in snow? is it waterproof and reliable?
Which has a shorter antenna the UHF or the VHF version?
Which would have the longer range in the the mountian?
Thanks,
Moshe
chrismol1
Saratoga
#2
The BPR40 has C/D/E/F in MIL-STD-810
I think the "Mag One" VHF antenna 5 1/2 inch and the UHF is 3 1/2 inch
VHF is best used outdoors
#3
Thanks,
Moshe
I've used the MagOne before (although admittedly, not in the snow); however, my biggest issue with them is that they appeared to lack the volume output of other radios (HT 1250, XTS 3000, etc.) Understandably, these radios are designed for different markets/purposes...however be sure to actually check out one of these radios for yourself prior to purchasing.
