Magnetic antenna and scratches?
kelltara
Question: I was using a bit of saran wrap the last time out to keep the magnet from scratching the paint. Is there anything else I can use such as a piece of felt?
DPD1
Yes, but if it's too thick it will lower the pulling power at some point. If the car is clean and you don't slide it, it really shouldn't scratch.
davidmc36
South East Ontario
If the bottom of your antenna is a bit rough and could cause scratches I use a layer of electrical tape, not too thick and is fairly soft. Just make sure there is no dirt or even dust before you sit it on.
n5ims
Also note that with mag mount antennas that the coax will move due to the wind and over time will mar the paint, so don't just worry about the mount. I know it sounds wierd, but a perminant antenna mount may actually do less damage than a mag mount.
