HP-2: Magnetic mount
Point Nemo.
#2
It won't hurt if it's just the antenna connected to the scanner. Make sure there isn't any amplifier in line with it.
Since the antenna is designed for 700-800MHz as well as 1900 and up into the 2GHz range, it's going to work best on those frequencies. You'll find some public safety traffic in the 700-800MHz band.
Since a lot of radio traffic is also down in the VHF and UHF bands,where these types of antennas are not designed to work, it'll be a very poor performer there.
Ideally you want an antenna that is designed for the frequencies you plan on listening too.
Point Nemo.
#3
I'll add:
The radio is only going to work as well as the antenna it has.
Installing a proper antenna will get the most out of your radio. Using an incorrect antenna is going to result in disappointing performance. Considering you probably spent a few hundred bucks on the radio, it would be a very good idea to follow up with a suitable antenna.
PA
#4
The OP is referring to a mount to hold the radio, not the antenna.
The scanner is not going to be hurt by the stray magnetism from a magnetic mount. Flash memory is not magnetic storage, so magnetic fields will not corrupt it or damage it unless you get into super-strong magnetic fields such as those found in a MRI machine.
