MagOne BPR40 Antenna
SteveC0625
Northville, NY (Fulton County)
Is there an antenna for the MagOne BPR40 other than the stock "stubby" antenna that might offer better range? I would need a UHF 450-470. Thanks.
The stock "stubby" UHF spike is the only one offered by Motorola for the BPR40.
If there are others, they're aftermarket items. You might want to do some internet searching.
