I recently helped out an organization with reprogramming a couple hundred Motorola MagOne BPR40 UHF Radios. During the process of reprogramming the radios several of the radios also needed to be brought within the narrowband requirements. Upon reprogramming the radio for narrowband operation the transmitter and receiver seem to have drifted off alignment. The receiver also seems to be much more sensitive as it is always open. It seems to be isolated to a batch of radios with the same codeplug R02.01.UV2 and some of them are even have chronological serial numbers. Upon performing a hard reset in the field the radios seem to return to normal operation.
Has anyone had similar issues with the MagOne BPR40 radios? It basically turns the radio into a paperweight unless a service alignment can be performed on these radios.
Any thoughts, suggestions, or ideas?
