Maher Terminals E-Port DMR TRS
RadioDitch
Field Operations Member
South Padre, TX
Another sleepless night inspired some searching for DMR frequencies around the family's place in Union County. I managed to get a bunch of hits...
462.17500MHz CC11
462.20000MHz CC10
463.25000MHz CC9
After investigation and license searches, I'm pretty sure I just accidentally discovered Maher Terminals' Capacity Plus system:
WQSE981 (MAHER TERMINALS) FCC Callsign Details
rr60
462.17500MHz CC11
462.20000MHz CC10
463.25000MHz CC9
This RR member has taken much of the work out of it. I suspect you may not have seen this database resource. You can import results into Sentinel too.
United States Digital Mobile Radio (DMR) Frequency Search
RadioDitch
South Padre, TX
Thanks, definitely a solid resource.
I was able to nail down 6 of the 9 LCN's for this system. Unfortunately, I didn't write them down before I cleared out of Analyze mode in a massive brainfart. I'll swing down to one my favorite diners down that way for dinner and let it run again.
This system is very, very active. For obvious reasons. Even without the LCN's, just monitoring individual frequencies, I've found at least 15 talkgroups.
Analogrules
Just update the db because not seeing anything for Maher Terminals included yet.
RadioDitch
South Padre, TX
I was holding off on submitting until I finished the LCN search.
RadioDitch
South Padre, TX
Still a work in progress, and I haven't had as much time this week as I'd like, but...here's the confirmed list so far with everything else still lacking a confirmed LCN.
461.950 LCN-3
462.175 LCN-5
463.250 LCN-7
463.875 LCN-8
I believe one of the frequencies on the trunked license is being used by Maher conventional analog, and 461.250 is being used as conventional DMR. Working on confirming that.
RadioDitch
South Padre, TX
Typing up a submission to the DB now, but pretty sure I'm still missing 2 LCN's...
