dcrispano
Can anyone tell me if Mahwah, NJ changed their Police and Fire frequencies?
The database listings are accurate.Can anyone confirm that fireground communications has also remained analog?
Fireground is still analog on 458.4625Note: Tone & voice paging is still being broadcast in analog mode.
Please advise as I'm just a novice.
As noted by W2SJW, you’re out of luck listening to Mahwah on your current scanner. Until such time that you get a digital capable scanner, you can listen to Mahwah online using your phone, tablet and/or PC at the following Links below. However you’ll see that both of these live feeds cover several other departments in Bergen County:
https://www.broadcastify.com/listen/feed/5861
https://www.broadcastify.com/listen/feed/28769
You can still listen to a few of Mahwah's Fire/EMS channels, specifically the following two which are still analog, not P25 digital:
460.2625 Fire/EMS Dispatch (you'll also hear DPW on this channel unless you enable the 165 DPL tone)
458.4625 Fireground (low power mobiles and portables, so you have to be nearby the fire scene to hear them clearly)
