Making coax stub filters
KF0AWL
Hobo
Iowa
I just found out about making stub filters and have watched videos, and read how many websites.
But can anyone put in laymen terms how to formulate making one?
I understand the words I'm reading but they don't seam to be making sense. 🤷
nd5y
Wichita Falls, TX
You use the electrical length of the coax. That is the free space wavelength called for (usually 1/2 or 1/4 wave) multiplied by the velocity factor of the coax.
KF0AWL
Hobo
Iowa
Yup I read that but I'm just learning all this stuff and I'm more of a learn by doing it person so I'm trying to get a layman's (dumbed down version of what I'm reading) lol
prcguy
As an example say you want to notch out a strong FM broadcast station at 97.5MHz. To find a 1/4 wave in free space for 97.5MHz divide 234 by 97.5 and you get 2.4ft. If you were to use a particular brand of RG-58 coax for the 1/4 wave stub it might have a velocity factor of .66 so multiply the free space 1/4 wavelength of 2.4ft by .66 and you get 1.584ft. That is roughly how long a piece of RG-58 coax would be hanging off a T connector to act as a notch filter at 97.5MHz.
In the real world you would now have a target length that could be off a bit so you might cut 1.7ft of coax, put a connector on one side and use an antenna analyzer and cut a little off at a time until it shows 0 ohms impedance and a very high VSWR at 97.5MHz when attached to a T adapter and a 50 ohm resistive load on one side of the T adapter to simulate whatever circuit you will use this thing with.
KF0AWL
Hobo
Iowa
Ok and I can find the velocity factor how?
You made it simple enuf I followed it 👍
prcguy
Search the brand and model of your coax for specs and the velocity factor will show up. I will be different between brands so you need to find the exact specs for the coax you are using.
Or if you have an antenna analyzer you could use a velocity factor around .8 for foam type dielectric and .66 for clear polyethylene then cut the cable extra long and tune with your analyzer. The point of 0 ohms on the antenna analyzer will come at a lower frequency when the cable is too long and you cut small sections off and walk it up to your desired frequency.
KF0AWL
Hobo
Iowa
👍 just watched a video on finding velocity factor. I think I got this 😁
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Not sure why you need one, but I make them before I buy an expensive filter to be sure a filter will actually filter out what I’m having problems with. Whew!
They are usually too broad to leave in and have harmonics, but are a good troubleshooting tool, for me at least.
KF0AWL
Hobo
Iowa
Want them for POTA when we use more then one station. Get interference and want to drown it out
iMONITOR
Silent Key
S.E. Michigan
Does all of this introduce any loss?
KF0AWL
Hobo
Iowa
Ok another question. Watched a video on determining velocity factor with a MFJ analyzer. Following his instructions I'm trying to get my first dip (he gets it to zero) mine only drops to three. Is this ok to work with or is something out of whack?
