Hello,
I have a couple questions related to proper grounding of the radio and also the antenna tuner in my man pack rig.
Also a question related towards correct installation of the antenna counterpoise/radial for the HF antenna on my man pack rig
I currently have a ICOM-7000 and a IT-100 antenna tuner in an aluminum framed housing. Please see link - Radio Station Antenna Tuner Backpack Frame for Yaesu ft 817 LDG Z11 LDG Z100 Ham | eBay
I have done some research already but I’m coming up with conflicting data and honestly I’m a little confused, any help would be appreciated.
1) I currently have a 10 gauge ground wire from the radio ground lug to the framed housing and also a separate 10 gauge ground wire from antenna tuner ground lug connected to the framed housing BUT THESE TWO GROUND WIRES ARE IN TWO DIFFERENT LOCATIONS ON THE FRAME. Should both ground wires be connected to the exact same location on the frame? Is my current setup creating a ground loop?
2) When speaking of the antenna counterpoise/radial for my HF antenna (MFJ-1979 & MFJ-1899) I assume that the correct radial should be a length of wire extended from the framed housing extending outward away from the radio in a ¼ wave length per the particular band being use. Is it correct to say that the counterpoise/radial can extend from the framed housing or does it need to extend directly from the lug on my 3/8-24 adaptor (see link) or should it be connected directly to the radio and antenna ground lugs? NCG Antenna Mount Adapters AD-35M - Free Shipping on Orders Over $99 at DX Engineering
3) When using the complete rig indoors connected to my roof top antennas can I simply connect a grounding wire from my radio frame to a known good ground connection that connects to a buried ground stake outside of my home?
Thanks in advance,
KD8HVN
Ray
Thanks in advance,
KD8HVN
Ray
