If I am scanning, let's say my favorites list, and I hear a call on dispatch and the officer tells another officer, go to channel 4..... is there a way for me to manually click through the channels I have pre programmed easily? Ya know say I was on channel 1 and wanted to click up 3 channels ....or maybe another time I want to click up 5 channels.... how would I do that quickly and easily? The old scanners had a "monitor" then you could manually advance up the pre programmed frequency list that you wanted to choose.
Not as happy with this 536 as I expected. Between the remote access for Android not being out for more than 2 years since it's release and some of the simple features seem to have been eliminated. I wish I had bought the 996 for a lot less money.
I seem to be here doing this quite a bit lately, but I'll keep doing it because I believe it---- and that's offering words of encouragement--- the 536 is the best scanner you can get, bar none. The learning curve for anyone coming from anything other than a Home Patrol scanner is steep and arduous, but the payoff is that you get incredible features that will work to your advantage the more and more you learn and use the radio.
I know the disappointment with the Android app--- I and many others have been all over Uniden about that here for nearly 2 years and we're not quitting. Some programs like ProScan ($50) can nicely fill that gap, although not on an Android, but on a tablet computer.
I have been monitoring communications for close to 60 years, and have had practically every scanner that was ever made. Nothing has ever come close to the 536 (and it's little brother, the 436) in the history of scanning and scanners.
So do not be dismayed--- many of the features and functions on the 536 are someone "nuanced", and it takes a little time to learn all of the features that the radio holds. The manual leaves much to be desired, but as you study the radio close up and use it frequently, little surprises are in store for you, and then perhaps you will understand why I am so enthusiastic about the radio.
