I very much appreciate all the help guys, this is my first go a discovering/tracking down a signal of this nature.
I did turn on the IFX this morning, and plugged the 100 into my computer to log via proscan, letting the scanner record the "audio". In the 4.5 hour run, it logged 248 hits, which is just shy of 1 every minute. I am seeing most all hits are 9 seconds long, some are as short as 6 seconds, but its not the typical 1s burst from CAP+ (frequency between bursts is way off too).
Now I switched filters half way through. IFX + Normal = -97db, IFX + Inverted = -104db. Duration of hit is unchanged, and I had "DMR CC12" noted in both. All recordings still are only between 1-4 seconds.
drive.google.com
drive.google.com
The recordings do sound a bit cleaner.
I'm going to run the second half of the day in IFX+Normal, plus turn it to digital only, to force it to decode? I will also turn the "delay" to zero.
