MARCS default in BCD996XT
Does anyone know (fer shure) if the default MARCS system in the Uniden scanner is up to date (more or less)?
Is there any point to scanning the whole thing since I normally seem to only hear three control channels - Beachwood, Chesterland, and Shalersville.? I'm hearing a lot as I set up a seperate MARCS system in addition to the default Ohio MARCS.
mdulrich
Van Wert, Ohio
I'm sure it is rather dated as there have been many new sites added since that scanner came out. I doubt if they keep updating what is in the radio before they are shipped. I would only monitor the sites you can receive.
Mike
