Looking for but can not find on RR the Freq for Preble County Ohio, City of Eaton Ohio and the OSP for Dist 5 Piqua Post. I have looked twice for these and have not been able to find them.
It's there under OSP District 5 Talkgroups
Thanks for the info on Eaton OH VHF that help on that. I seen the info in the OSP and Sheriff Dept. but it list the DEC info and I was looking for the 7XX.XXXXX freq numbers because I program them manually.
Thank You
Ned Hines
As budevans and W8SQY gave you the information for the County stuff on MARCS... I just want to throw this out there...
You asked for "City of Eaton"; if so, they are still on their VHF radios - not sure when, or IF, they will switch-over to MARCS with the County, and....
If you are wanting the info for OSP that covers Preble County; you should plug in the OSP District 5 Post 57 (Dayton) TGs.....
Hope this helps,
The merger was delayed because of delays in merging records and upgrading the CAD system, also EPD never went encrypted, at some point over the summer they shifted dispatch to the TAC frequency (151.0175), I never heard why, but I would guess something broke and they decided not to fix it (since the merger is coming). In the past month EPD dispatch again moved, this time to the old Preble County VHF system where they’ve been using the old Sheriff’s Dispatch freq (155.61). Again, I never heard why but it should only be temporary. EPD dispatch is scheduled be merged into the PCSO dispatch center on May 1. Post merge they will be using MARCS and much of the old VHF system will be decommissioned.Actually as far as I know, Eaton Police is encrypted. They were operating on 151.1825, and when the "County Merger" happened, everything on that channel went silent. Every so often, I'll hear this bizarre digitalized racket.
Preble County Fire, gets dispatches on 159.3825, but 98% of the operations are on 700MHz.
"NSfan98, post: My question now is, what are the TGID's going to be for EFD/EFD TAC & EPD once they switch over to MARCS?
Hope this helps,
Any help on that end would be appreciated for any of you Preble scanners!
I’ve been running discovery with an HP1 on the West Alex site since early May in anticipation of the change over, there are a few newer 41xxx groups that had hits, but only test traffic. I’ll update once it’s more clear.
No need to, at least for now... They are being dispatched by County on TG 54854, using their County-assigned 12xx series ID's....
