sopranosno1
- Joined
- Dec 19, 2002
- Messages
- 590
the fcc has seventy seven 700 mhz frequencies pending for the state of ohio....
Where do I begin!!!will parma merge their TRS into this one once its done?
Where do I begin!!!
Politics (ego's), Finances (costs) and last but not least Vendor P25 compliancy issues (Moto P25 vs Ma/Com P25). Everything will work just fine as long as the other guy will match our version of compliance.
you are right. thanks for the correction. question, i found two web pages with 700 mhz public safety
freqs. one at wiki radioreference and jts203.com. problem is there is a difference. one has 769 to 775. the other 764-766 and 773-776. why the difference?
4. Eventually will be interconnected with Lake County and Lucas County systems as well as MARCS
Does this mean that the current Lake County TRS, will be upgraded to ASTRO 25 platform 7.x?
Yes, Lake County will eventually have a 7.X simulcast cell attached to the zone controller/master site already installed at the Lake County EOC. The ZC at Lake County will have interzone links to the states ZC's in Columbus so roaming between Lake & MARCS would be a possibility.
Right now Lake County is using a SmartX converter to connect the existing 7E26 system to the 7.X master site & MCC7500 consoles, so they are already making progress towards a full Astro 25 system.
The 700 MHz Cuyahoga MARCS system & the future Lake County system will use linear simulcast modulation (LSM). Search the forums for some of the difficulties experienced by listeners in Lucas County and elsewhere decoding these systems.
1st: Do I set my scanner (GRE 500) for Moto 800/900 or P25 Auto?
2nd: Does the above mentioned Linear Simulcast Modulation pose a problem for the GRE 500?
Note: I currently receive the Parma P25 system without issue. Parma P25 is listed as a three site simulcast system. I don't know if Parma is using LSM.
Any suggestions, would be appreciated.
The Lat/Lon of Location #1 is the exact location of the "pole" I referenced in post #7. This is less than 2 miles from my house, so I will be monitoring those frequencies.The FCC issued the radio license for this system today. The callsign is WQME391.
So maybe I'll notice a new antenna for 700 MHz going up...? What would that look like?
