budevans
Cleveland, Ohio
TG40567. Has anyone monitored or identified this TG?
I caught the tail end of a transmission from this talk group around 6:20 p.m. today.
When I looked up the TG range in MARCS, it looks to fall inside of the range for Portage County. I see TG40566 which is Portage, County Wide Tac 8, Interop. Also TG40571 which is Portage, Ravenna City Wide Fire Alert.
northernsummit
Macedonia, Ohio
I have a number of transmissions over the past two days.
15xx units
100 is dispatch
They're using BSSA Sheriff radio codes and are some type of law enforcement. Maybe Ravenna based on a domestic on Lakewood Rd. Talk about shutting down Loretta "on our campus" during the storms tonight. Not sure if that is KSU, NEOMED, something else?
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
15xx units
100 is dispatch
Sounds like it would be NEOMED. Of course NEOMEDPD is already in the database as 40504. Perhaps they moved, or perhaps 40567 is a Tac / Talk talkgroup for NEOMEDPD. Those of you who listen to Portage shoudl attempt to pay attention regarding whether NEOMEDPD is heard on 40504 anymore. If there is no more activity on 40504, then it's a good bet that they moved to 40567.
The wiki says that 15xx units are NEOMED PD.
mike
fpo701
OH DB Admin
Akron, OH
I'm with Mike. Loretta is one of the roads that leads into the NEOMED campus. This is probably a new NEOMED PD talkgroup, assuming someone can verify that the existing talkgroup has been abandoned.
Aurora, OH
40567 is a NEOMED talkgroup. 100 is Portage Co. Sheriff Dispatch. This talkgroup was recently added when additional Portage Co. agencies started switching to MARCS. Never heard it used until today when the storm blasted through Rootstown. Not sure if they are still using the 40504.
