Maryland Aviation Administration
Anne Arundel County, MD
#1
Has something changed that I am not aware of?
Trying to program Maryland Aviation Administration into SDS100 and SDS200 and I am finding it tracking what appears to be the right Trunk frequency of 852.3250 but I am getting no reception of activity from the system even though I get strong signal reception.
Turned on a 325p2, 996p2, and 996xt and all are receiving fine.
I checked and for some reason cannot receive on the 436 or 536 either. That led me to look at service types, and all are active on all 4 radios. I found 2 lines of bandplan data in addition to what I had programmed to the working radios and matched those up. Still getting control channel tracking on the right control frequency but no activity.
I am sure it was working on the 536 not that long ago as I monitored the ice storms a few weeks ago.
The fact it works on the 4 radios I mentioned, and not on the others suggests a programming issue but currently stumped and looking for ideas.
Having no problems with any other systems, including AACO, FiRST, BaltCity, BaltCounty, CMARC (including Harford), Howard, JNCR (Meade & Naval Acad) & MdTransitAdmin.
Any thoughts?
I am using the same Sentinel database on all 4 radios with issues, but I can't see anything wrong with the setup in the radios.
SDS100&200/536/436/WS1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
ThePhotoGuy
Maryland
#2
No idea but just wanted to let you know that this thread and the "UMESC system" are showing up in the Breaking News section so people might not be seeing these as much.
#3
Oops. Meant to put them under Maryland. Must have gone a thread too deep.
**** Maybe Admin can fix ****
Figured out my Aviation Admin issue. Recreated favorites lists for the radios involved and back in operation.
Obviously a corrupt file. Probably the first thing I should have tested. Faked out by everything else working.
