Might wanna read this
http://forums.radioreference.com/un...are-1-03-01-public-release-2.html#post2959490
So, I thought the idea of site NACs was to differentiate sites that share the same cch to prevent interference and/or radios from mis-affiliating with the wrong site? Is this good practice to assign the same site NAC to sites that use the same cch?
I have a question about bandplans wrt First. I notice that the BP radios pick up from the system has entries for 762.00625; 851.00625, (and 851.0125 for 12.5 spacing) and 935.0125 (12.5 spacing) when using the AACo simulcast site. Do the three separate entries allow for the radio to interoperate on other 800 and 900 systems in addition to its home 700 system? An additional question: for users who have multiband radios - like Allegany - will they also have an entry in the bandplan for the UHF / 450 range? Is that BP downloaded from specific sites? Is the BP downloaded each time the radio affiliates with a site? Or would the 450 info be hardcoded into the radio since in their case, the 450 system is not P25?
Motorola radios primarily ID control based on a combination of broadcast WACN, System, Zone, and Site IDs as determined by the System Type programming field. If they hear a CC on the right frequency, they'll listen for the appropriate combo of information per their settings on how big to listen for, and determine whether to try to send a registration burst. They can be set to validate NAC against System ID, but in practice I've seen that very rarely used.
Again this is all for Motorola:
1) These separate entries just allow for appropriate control channel reference to RF channels in different band splits (true different bands OR different channel spacing like 12.5 vs 6.25 OR double the channel numbers due to TDMA slots) to be clearly understood by the radio. The reason for the 800s is that this layout of bandplans is pretty standard among 700/800 systems and they tend to keep it consistent in case of future expansion/changes.
2) The bandplan broadcast for MD FiRST ONLY applies to MD FiRST. Motorola radios are configured with individual bandplan entries under each Trunked System entry in the codeplug, and do not receive their bandplans over the air.
3) Allegany users will have separate Trunked System entries for UHF systems in the area that will have their own bandplans pre-set.
4) I believe P25 requires the bandplan to be broadcast, but Motorola radios are pre-programmed with the correct bandplans and will not function on a system without its properly configured bandplan entered. They don't use the over-the-air bandplan at all.
Hope that helps. Literally AFAIK the only reason you're hearing a bandplan broadcast at all is because the P25 standard requires it as part of the CC information. I have no idea if Harris or BK radios use that information OTA, but MSI stuff doesn't at all. You set the bandplan wrong in CPS, good luck transmitting on the right inbound control channel freq to register/affiliate - radio will just get confused and say OUT OF RANGE or NO COMMS. They're not nearly as smart as we might think
Is there a list of UHF P25 frequencies that will be used in Allegany Co ?
Does anyone have any idea why an agency would "go to channel 2 for the week"? QA Co Law Dispatch sent all users to Law 2 for the week, beginning at 6m today. Law 2 is encrypted, and hasn't been used as much recently, as it was earlier. This wouldn't seem to be an abnormally troublesome week to be using it. The quirky part is neighboring agencies are having some difficulty using their Law 2 when asked. Only sporadic garbled/encrypted transmissions are heard on (currently unencrypted) Law Dispatch.
Interesting.. can anyone translate (Cecil Cell move from Zone 1 to Zone 3)
for me? Not sure what that means.
I won't matter to you as a user, and you won't have to change any programming in you radio. It's basically being done to optimize core resources. Cecil moves from Zone 3 (essentially the Baltimore region extending to WMd) to Zone 1, which covers the Eastern Shore. The system will have 3 primary cores, the last one looks like it will cover the DC Metro counties and SoMd (Zone 5.)
While it may not require changing programming (for scanner users). The Cecil Site will likely change from the current RFSS ID of 1.4 to a 3.X site ID (X being whatever is available 1-12 are in use).
And the Cecilton ASR as well..
IDK??
In roughly chronological order - nothing earth-shatteringly new was discussed, except for St. Mary's:
Talbot 2 channel upgrade is complete as of mid November, and is expected to reduce system busies in the area. The system manager meets tomorrow with the "federal agency" who is allowing a FDMA radio to sit on Talbot's dispatch channel, which essentially ties up three resources when in use. I suppose they will "encourage them to upgrade or replace the offending subscriber. The Delaware FDMA situation is also being addressed with a meeting this week with "the right people in the room." The Talbot site is the second busiest in the system, and the Wye Mills tower receives the most traffic. The upgrade was funded by both the county and the state,
