WX5812
I have a uhf executive mastr ii converted into a repeater. Is there any way to remove the PA and use it as a uhf amplifier?
It has been a while. I don't remember there being two RCA jacks, but yes, it will be an RCA jack. There is a jumper between the output of the PA and the lowpass filter. I had to resolder that one more than once because it gets pretty warm under power. It wouldn't hurt to check it before using.Yea I have plenty of fans to keep it cool. So obviously the output is already wired for a so 239. So the input is one of the 2 RCA jacks?
I have an attenuator that I saved from the scrap years ago. Would this one work? It’s adjustable from 0-70db
Single Knob 50 Ohm Manual Attenuator 0-70dB x 10dB Steps DC-2.2GHz Model 50R-029 - JFW Industries
I’m found to be driving it with a Motorola Maxtrac. I’ve seen online somewhere that you can bring that thing down to 1 watt please correct me if I am mistaken
When you say the maxtrac will give me grief below 20 watts what do you mean?There are 2 RCA jacks the one on the left is into the IPA the one on the right should go to the RX. You can bypass the whole IPA and go in to the PA at I think 5-10 watts? Easy to find out transmit and see how much power is driving the PA. That looks like a 40watt unit.
Bringing the power out down on an Maxtrac is tricky, if you have a 45 watt unit anything below 20 watts is going to give you grief, if you have a 25 watt unit you can go to about 5-7 watts.
