Math Mark Limited MML Dual Band UV-100 256ch. Portable Radio
Hoseman292
39.019986,-77.01298
#1
Gents,
It arrived last evening from overseas with new battery, antenna, and desktop charger.
The only item missing of concern is the software.
Embedded on the radios chassis is a sticker with the company url, http://www.math-mark.com/
which stalls and returns this message:
Bad Request (Invalid Hostname) which reoccurs roughly half a dozen times on a half dozen web searches.
Now completely bug eyed half way tempted in simply boxing it back up and returning to the eBay vendor but
opted in fairness to be patient and await a response. The one page manual refers to the software as "optional" along with two or three other features initially indicated as included. Scrambler, MSK, 2 Tone, 5 Tone, and 1750 / 1250Hz tone, now have "Option" in parenthesis.
Question... anyone ever played with software for one of these radios?
Thanks,
Tim
mancow
N.E. Kansas
#2
I saw these on ebay and if it's the same one it mentioned it does frequency hopping. Does yours have some sort of feature like that? I was tempted to get a couple just to see what they do but was afraid it was typical Chinese marketing that had nothing to do with reality.
#3
Math Mark MML UV-100
I just ordered 3 of these radios. I also saw them on E-bay. I hope I have not wasted my money. I also did a search for any information I could find about these radios and the company. I also hit a dead end in my search. It is my best guest that this company (Math Mark), has gone out of business. They do not seem to exist anymore. I did find that they made other electronic products, although, find nothing to suggest they have ever made radio equipment.
My radios should arrive in a few weeks. I will post again when they arrive.
Looking at the picture of the radio, I would assume that it could be field programmed through the keypad. We will see when it arrives. I ordered these radios mainly for FHSS feature of the radio. I hope this does not turn out to be another feature that is optional, but not installed in the radios, otherwise, my purchase of these radios was a waste of money !
#5
I ordered three radios. They have not arrived yet, but they are in USA now. They should arrive any day now. As soon as the do, I will have to try this software download.
#6
My radios just arrived yesterday. I could not find any place to plug a cable into the radio to program it. I figured out how to program frequencies into it, but it is a bit annoying. I also figured out how to frequency hop by pushing a button on the radio. The frequency hopping only last a few seconds. It would be nice if I could configure this radio to frequency hop all the time.
KD8DVR
Columbus, Ohio
#7
Is there also a sticker with the FCC id? If not, then these radios are illegal in the USA.
They DO sound interesting though.
Gents,
Embedded on the radios chassis is a sticker with the company url, 加减乘除(香港)有限公司_加减乘除对讲机
Tim
#8
Softeare
I wonder if wertoz could upload the software again the link he provided doesn't appear to work. Would really like to get some software for the UV-100.
United Kingdom
#9
Math-Mark MML UV100
I now have two of these radios and the software uv100.exe direct from the factory ( i asked for it in badly translated chinese before i bought the radios) with the badly written handbook. Just getting to grips with these radios. The first thing i notice is that they look like the Puxing Px888 and on checking the batteries at 7.2v found that the spares that i have for my px888 fit perfectly and are the same voltage, so spare battery problem solved as i have 4 of plus the two provided with the UV100's.
The programming is not much different from many of the chinese cheap handhelds. They use the kenwood 3.5/2.5 (two pin) USB programming lead which i already had. They are strange little radios to program as you have to start the program first on a windows box (I use an xp laptop, the slower the better for programming), Next plug in the radio (unusually, you TURN the radio ON prior to connection to the computer, failure to do this will mean the radio will not boot up and stay blank screen). Once connected READ the RADIO and store the file for a backup image, in case of problems. The com port was recognised in the settings, drop down menu and highlighted for me to select (easy so far). Several 2m vhf and 70cms UHF frequencies later the radios were programmed. With 6.25 steps selected these radios are very flexible when entering frequencies and all channels set to Narrow Band. Next after checking them back to back, i opened my local UHF repeater with the required CTCSS and bingo, no problems there. The CTCSS is very confusing as they have 3 settings C, Rx and Tx but it turns out that C is just short for combined so if ctcss is selected in this menu the radio applies ctcss to both tx and rx frequencies, as i only need it for tx i used option 3 the tx only. The radios also have DCS and inverted DCS that can be selected. A nice touch on these radios is the change of colour when you call via keying up or sending ANI codes to activate with a ring and colour change and a vibrate mode. (ANI codes are four figure and set up by the user in the special programming page along with group ID numbers, you can basically make up any group or id number you like). The ANI system is activated via the DIAL (some very strange names are given to functions on chinese radios) setting and tested and worked fine, both radios tested and would wake up on pressing PF2 extra button on side of the radio. (PF1 being the TX key and PF3 being the squelch defeat). Next was to try the scrambler funtion which has 8 settings programmable only by computer (so once selected, you can only change the scrambler frequency by computer (like most chinese radios that claim to have a scrambler on board, they dont in fact have scramblers, but Voice Inversion x 8 settings, but good enough to defeat the casual scanner listener to your conversation if you feel that you have something that important to keep secret lol.
So what about the FHSS (Frequency Hopping Spread Spectrum) I hear you shout, well a bit of experimentation and guess work led me to what is described in the handbook as "the secret Call of the Military High Level, which is pigeon English for FHSS. To activate you need to turn the menu on the radio to allocate PF2 button to FHSS on both radios, they call it PLOT, then pick a simplex channel on both radios, the algorithm to activate is sent via a squirt over the anologue channel on the radios. When sent it will ring/light up/vibrate radio 2 and switch it to PLOT automatically. So are they really FHSS, well sorry to disappoint I used two different frequency counters and my Albrecht AE230N (which has close call on it to fix on transmissions). On the first try, the radios once filled with the squirt code moved off of the calling frequency and moved to a frequency that i had not programmed in? They were clearly picked up by the scanner and both frequency counters and both radios talking back to back on this channel did nothing to change the frequency, just an obscure frequency in the 400mhz to 410mhz. The only way i could get them to move was to re-squirt with PF2 and they then changed to another random frequency in the same range UHF. I found that if you did not tx for 45 seconds the radios would then go back to the calling frequency and come out of PLOT mode. I have been back into the programming and changed the timing under the plot menu to 100Ms hoping that i could get them to hop frequencies, and tried various other settings to no avail. I will be putting the radios on a spectrum analyser at the weekend to find out if i am missing something. But the long and the short of it is that "the secret call of the military high level appear to NOT be FHSS, but jumping to a random pre-programmed frequency and staying there until they are re-squirted with another code, or am I missing something here? If anyone has anymore information or experience with these radios i would be very interested in your thoughts and experience as it is only day two with the radios and i cannot find any FHSS on the radios. I have used FHSS radios as i have a pair of TriSquare eXRS 900mhz FHSS radios which work fine and throw my frequency counters off the scent and after an antenna mod for BNC with 900mhz antennas on they work fine.
So the long and the short of it so far, is that i have bought 2 nice quality puxing look alikes dual band for 50 quid (£50), so i am not complaining as they are definitely much better quality than the Boafungs and the other cheap and cheerful dual bands available at that price. The Math-Mark MML UV100 is definitely good value for money, just a pity that the FHSS does not work?
Finally toxicated101 if you would like to email me at 2e0aiv@2e0aiv.co.uk I will send you a copy of the UV100 programming software for your radios, maybe you can find something about the FHSS that i have missed? If you have all read this far and not fell asleep, well done. I hope my small offering of a revue has helped some of you?
Regards
Andy
2E0AIV
Hoseman292
39.019986,-77.01298
#13
I ended up returning it. Original listing advertized the radio included 2 Tone which was the main reason I decided to buy. After numerous e-mails the seller finally confessed, "radio is simple version.. so sorry".
After a few additional e-mails made solid deal to exchange for the radio advertized.
After waiting a few weeks, equipment never arrived. Seller claimed "lost in mail" and Buyer Protection
(not the seller) returned $60.
Ordered a TYT TH-F8 with 2 Tone.
Strange enough, two tone decoder works flawlessly with service monitor. Decoding local fire dept. selective calling fails.
gewecke
Banned
Illinois
#14
They seem to be the same variety as the "shop888" radios so my $$ will stay here in the USA. ;)
73,
n9zas
Hi do you still have a copy of the software?
