max systems vs. radio shack 800 mhz
jlmeade741
This is what I found with the testing I have done(4 days). I resently purchased a Max Systems 8HH and a 8BA. Tested against my Radio Shack 800 mhz Antennas. I live in a brick home, so my receiving isn't the best inside, but here we go. As far as in home reception I could not tell any difference. When I moved my scanners outside, both Max Systems Antenna picked up more(three sites) than the Radio Shack 800 mhz antennas. I also found that my Pro-96 picked up more than my Pro-2096. Will keep testing and keep you informed. Have 2 yaggi antennas but don't have them up yet. Let you know. Happy Scanning!!!!
Dubbin
Findlay Ohio
I'm finding that my RS 800 works better in the house then the Max. I have never tried Max outside though since I don't want to take the chance of stabbing myself in the side :)
