MCS2000 Antenna connector?
Some random guy on the internets.
Point Nemo.
#2
The antenna connector on the rear of the MCS2000 is a "mini-UHF".
You can purchase NMO antenna mounts with these already installed, or with the connector loose.
East Texas
#3
Mini UHF to NMO
The NMO connector is normally part of the mobile antenna mount, whether it be a hole, trunk lip or magnetic mount. You can buy the cable kit with the mini-UHF connector already attached on the other end.
