MD-380 VHF, locked out of programming
mancow
N.E. Kansas
I picked up a VHF MD-380 and must have somehow written a default codeplug or something. I am locked out now. It asks for a password when attempting to read or write but I don't know what the password is. 00000000 doesn't work, nor does nothing in the box or any other combo that I've tried. Also, when I try to manually program it once I enter the user password of 00000000 it says unlock but then immediately goes to lock again. I can't get in at all.
Any ideas?
I would try to READ from radio in the software and see what the passwords are. If that doesn't work, just load a new one with whatever passwords you want.
KevinC
Junior Radio Guru
Super Moderator
Home
He states he can't even read it.
Maybe reload the FW and see what happens?
mancow
N.E. Kansas
I've tried firmware and everything. I even looked in the ini file which says it should be 777777 but that doesn't work. Nothing works.
See below from another group....
Posted by: n2nuo
Go to the directory where the software is installed. Usually Program Files -> Tytera -> md-380.
In that directory is a file named "settings. ini"
Look for "Password= 1" change it to "Password= 0" save the file, program your radio.
mancow
N.E. Kansas
Posted by: n2nuo
I have tried that as well but it still asks for the password.
mancow
N.E. Kansas
What happens when you try to clone a password protected radio using a clone cable? Does anyone know? Does it bypass the password?
tango1179
Gainesville, GA
MD-390 - but EXACT SAME PROBLEM
Any ideas?
I am having the EXACT same problem with my new MD-390. I have tried all of the suggestions in this thread, and nothing is working. If anybody has any other suggestions, please send them.
jonwienke
More Info Coming Soon!
VA
Once you set the "PC Programming Password" in the General Setting dialog and write to the radio, you have to input that password every time you attempt to read from or write to the radio. If you change it from the default (which is set to nothing/null at the factory) and forget the password, you've essentially bricked the radio, at least from the perspective of editing or updating the codeplug.
It's a deliberate design feature to safeguard the privacy keys. Otherwise you could "borrow" a radio programmed to communicate on a secure network, read the codeplug, and clone any number of additional radios that could listen to all the encrypted talkgroups.
There is a separate "Power On Password" that can be required on startup, which does not have to be the same as the PC Programming Password. It can be changed by reprogramming the radio, but that requires you to know the PC Programming Password.
If you lose the programming password, you can't read or alter the radio programming. If you lose the power-on password, the radio is a brick.
Turning the radio on while holding down PTT and either the top or bottom side button (I forget which) puts the radio in a special boot mode where you may be able to overwrite the old code plug with a new one and wipe all the old passwords and privacy keys.
tango1179
Gainesville, GA
EUREKA - I have the answer
I have been in contact with TYT overnight, and their software engineers have made a program for the radio that will bypass the need for the password. I have tried it and it works fine.
Kudos to the software engineer at TYT for getting this done in such short order.
Unfortunately, I can't attach the file to this post because it's too big.
Private message me if you need the file, and I will send it to you.
jonwienke
VA
Not aware that any TYT MD-series radios support cloning.
mancow
N.E. Kansas
The only way I found to fix it was to use the Travis Goodspeed linux tools. I read a friend's radio to caputre the image file then wrote that to mine and it was back to normal.
I_am_Alpha1
How big? Could you put it online via DropBox or Google Drive?
Tombofix1948
St Albans, Herts, UK
How the hell
Do you message someone on this site?! I can't even find my inbox. Desperately need the tool tango1179 is talking about as a CPs Flash failed corrupting the Programming Password.
Tombofix1948
Hi All,
I have spoken to TYT and they have given me the software to bypass the password and get the radio working again! The instructions are as follows:
1: Download the software (https://www.dropbox.com/sh/rdt7j67ou9y4x72/AABKjxs-zxrwZ7jjwUUY6h14a?dl=0)
2: UnRar the file
3: Run DMR.exe
4: It looks like the normal CPS but it doesn't like pre-existing codeplugs. Connect your radio and download the data (you will not be prompted for a password).
5: Alter the code plug you have downloaded and fix the programming password
6: Re-Image the radio using the updated code plug (you will not be prompted for a password).
7: Close DMR.exe
8: Re-Image the radio using the correct Code plug from CPS v1.36 or your normal version.
kc1efx
Cape and Islands, MA
MD-380G
Hi All,
2: UnRar the file
3: Run DMR.exe
7: Close DMR.exe
Tried this but its not compatible with the gps version (MD380G)
Anyone have a different solution? I've checked out the GIT solution with MD-380 tools but can't for the life of me figure out where to even start. Anyone have a link to a step-by-step for installing and running MD380 tools?
