MD-380
n8jsw
Belmont County,Ohio
#1
Does anyone know if Travis Goodspeed's software for the MD-380 can be instaled on windows also or does it have to be on PI cause I would like to try it but have not had any luck with it
PA
#2
You'd have to recompile the source code into something that would run under Windows. It could be done, but is not a trivial exercise.
