MD 9600 programming software V1.21
eaf1956
Evansville, IN
TYT must be crazy! In the new software release they try to get you to limit the radio which causes your codeplugs not to work.
"Programming software: V1.21​
Before using this new programming software, please use the model software​
named as TYT9600 factory V2.014 to set the model first, please read from this​
software first, and choose 144-146/430-440MHz, then write into radio"
If like me, your codeplug was created with the range 400-480MHz and 136-174MHz it says out of range when you try to write the codeplug. This is also true for the CSV file. And if you try to change the range in the CPS it blanks out the codeplug. And some of the repeaters I use are not in the range of 430 to 440MHz
eaf1956
Evansville, IN
Has anyone found out how to choose Zone Separated or Zone Combined with the new CPS for the MD2017 and MD9600? v1.22
pcrover
Anyone have a FIX for this?
pcrover
Sounds reasonable. Can anyone point me to this Factory Software so I can download it?
Thanks!
