gkmccready
I have 3 TYT MD-UV390 radios programmed to digital frequencies. I've set Mic Level 6 on all the radios. My use for the radios is a crew and racecar scenario, so we have the Racing Radios car wiring harness connected to a Stilo helmet in the car, and another headset for the crew side. With this set up we get very weak mic pick up from both the headset and the helmet mic.
We tested the crew headset and third handheld radio, and the handheld was clear and loud, but the crew headset mic gain was very low still. Any of the radios without a headset connected are quite good for mic gain and volume.
We have tested the car and crew set up with Vertex Standard EVX-531 radios and they work much better. No gain/volume issues.
Is there some setting on the MD-UV390 configuration that I'm missing? Or is it just really bad when you plug in a headset?
Thanks!
glen
Thanks!
glen
