MD785 problem with Roaming option
SQ9JDO
Why Roaming does not appear on the radio screen in the menu. In CPS, this option is checked
Andrzej SQ9JDO
PA3CQJ
Andrzej SQ9JDO
For roaming you need to have a roaming license: Common>Feature Control>Feature Check
Rutger PA3CQJ
k4ktr
Elizbethtown,kentucky
you have to have a system set up for roaming to do this each ch that is part of the roaming system has to have IP SITE checked in each ch the roaming list set in the scan / roaming and then add each ch to the roaming list that should be it
