MDC issues on a HT1250LS+
paramedicqc
Quebec
#1
Hi,
I bought two different batch of motorola HT1250LS+ UHF. I use it on a 400mhz LTR system. When I programmed some of the radios, I was able to enable the MDC but only for the LTR system. I can't enable it for the conventionnal frequencies. What's weird is I was able to enable MDC for LTR and conventionnal on a HT1550LS+ I bought from the same police department.
Can somebody help me with this issue ?
I use CPS R.6 with Ribless programming cable.
Envoyé avec Tapatalk Pro
N1GTL
CT
#2
Some of the earlier HT1250LS radios do not have MDC for conventional channels.
So Cali
#4
You can decode the serial number to determine the date the radio was built. Also model number decoding to see IF the radio is capable of MDC or other features.
