mdc1200
njffemt08
Was emtfirebug14
#1
i am having issues with programming mdc1200. when i click write it keeps giving me an error message stating beginning of transmittion
njffemt08
Was emtfirebug14
#3
i found out what my issue was i still had it set on dtmf under ptt id instead of mdc1200. but now when i go to write to radio its only programming the 1st channel. not sure what im missing
In the 'patch
#6
Ok, when I get home i will look into it. When you say only programming one channel, do you mean only one channel is programmed correctly with MDC1200 signalling?
njffemt08
Was emtfirebug14
#7
No only 1 channel is being written. Onto the radio instead of let's say 32 channels being written
Sonoma, CA
#8
How many zones are you using and is there multiple channels in each zone? Also is the rotary knob set to channel and is the BC buttons set for zone change?
If these things get cross wired it may seem like you have only one channel.
njffemt08
Was emtfirebug14
#10
Kayn1n32008 where you able to look at software and see what I may be missing causing only 1 channel to be written onto the radio instead of all 32 channels
In the 'patch
#11
All I can suggest is to start fresh and rebuild your code plug and load it. Don't read the radio first. Do not use the same saved file. Select 'new' and hand enter all your frequencies/tones and signalling
njffemt08
Was emtfirebug14
#12
That's when I have the problem. Starting brand new with a blank program list. When I reuse an old list and edit it the radio programs just fine
