MDX Help
Muxlow
Super Secret
Middlesex County
Iv had this GE MDX for quite a few years and never been able to program it
I got a TQ3310 rib from ebay. Made a programming cable from here
http://neirg.org/staticfiles/ge/images/pinouts/tq3372.gif
Using a 12 volt power supply to the rib. Have the latest programmer and all that too.
SO!
I power the radio up in programming mode, push read on the software,
says power cycle to program mode -skiped that part since its in program mode-
Attempts to do a handshake and give the error
MDX Handshake not complete, use extended handshake?
I click yes and let it do its thing and it fails.
Next time i leave the radio off and then go into program mode when it asks. Same results
Then leave the radio on, then go into program mode when it asks, then extended handshake i follow what it says in the help file to disconnect the power from the radio for 2 seconds and reconnect. Nada
Do the same but for 5 seconds power disconnect. Nada
Tried just about every way i could think of and nothing.
Have the correct comm port selected. Checked the programming cable a few times and made another and nothing changes.
Even used a 9 volt, 12 and 13 volt power suply to the rib. No go.. How can i check if the rib is messed up?
Muxlow
Super Secret
Middlesex County
...Nevermind. I figured it out!
The diagram on that link is backwards. Pin 1 is on the right and pin 9 is on the left.
Switched everything around and now it reads :)
