Memphis Hospital Wing
Gatorman
#1
I notice the database has never been updated to reflect 152.9 as the dispatch frequency. However, I haven't heard traffic on this frequency for some time with the exception of what sounds like utility or maint. crews.
Can someone update me on Memphis Hospital Wing comms if there is an update?
Thanks!
Taxachusetts
#2
Did you make a submission for the DB???
That is the only way, the DB will get updated
Thanks!
The great state of Tennessee
#3
I was listening to them a couple of days ago on that frequency. The repeater is located in Nesbit MS on a 500 Ft. tower. It is not easily heard in all parts of Memphis without an outdoor antenna and or a commercial class receiver. Also using the PL tone helps to keep interference from being heard.
It is listed under hospitals -emergency services-first listing Wing Hospital Air Nesbit EMS Tac
http://www.radioreference.com/apps/db/?ctid=2506
I hope this helps
