Mesin
guyiv
Lower Delmarva
I just heard MEMA test of the MESIN on Worcester county's trunked system on tg 0360 and heard all the counties and oc check in i tuned my other scanner on to Wicomico's trunked system and didnt hear any thing just woundering if any body else heard any thing?
guyiv
Lower Delmarva
WCRadioGuy said:
I don't believe Wicomico has a MESIN TG tied to a trunked TG. I'll see if I can verify this.
I doubt they do come to think about it because they are Motorola and not EDACS and the MESIN is an EDACS network.
EDACSTECH
Ocean City,MD
Ocean City has MESIN networked to the Ocean City & Worcester County EDACS Trunked system without dispatcher or console intervention. This allows all city radios to interoperate with any MESIN user without setting up a console patch. You will not be able to scan MESIN calls from other users without a dispatcher patching MESIN to a trunked group or conventional channel unless others also configure their MESIN interface to their radio system. MESIN is "NETWORK FIRST" technology from M/A-COM but is not EDACS.
tolley
Hurlock, MD
In Dorchester the MESIN can be accessed through the NPSPAC channels or can be patched through to any of the talkgroups on the Motorola system.
WCRadioGuy
Salisbury, MD
This can be done on all the systems tied to MESIN.
EDACSTECH
Ocean City,MD
NPSPAC channels 866.0125, 866.5125, 867.0125, 867.5125, 868.0125 until rebanding then subtract 15MHz. MESIN can also be patched to any local Trunked or Conventional Radio System.
doctordave
dpm797,
Those NPSPAC freqs are also available for use in a similar way in the Balt metro area....almost never used, however. On a similar topic, any idea if the Kent radios are programmed with the V-CALL & V-TAC freqs (similar concept - just on high band) ? Cecil does have them programmed in. See this link for freqs: http://www.radioreference.com/modules.php?name=RR&aid=1632
Recent reports of NRP units using the V-TAC freqs at a boating event in Chesapeake City....possibly MSP as well.
dpm797
Millersville, Maryland
To the best of my knowledge, Kent does not have the V-tacs. MESIN is only in the dispatch center. The fire units have 154.280, for Mutual Aid. Not sure about Sheriif Dept.
Joseph11
In the MIMICS document, "FEDTAC" is mentioned. Anyone know what frequency that is?
doctordave
Since they seem to be suggesting ONLY a singular Federal freq, my guess would be the DHS / Federal Common freq of 166.4625.
