Message Backup Problems
KR7CQ
Phoenix
#1
I successfully used this app when I first got the pager but it no longer functions properly as far as I can tell. When I hit "import", it sees no voice files on the pager. There are 204 messages stored on my pager at the moment, but the program sees none of them. This makes backup impossible (all I really want to do is back them up for the purpose of exporting them and saving the files I want, which I did previously).
Also I would like to delete the 2,000 files stored somewhere on this computer but I cannot find them. I tried what was suggested by Troymail in another post, but there were only log files in that folder mentioned, and deleting them accomplished nothing. There were no Wav's in the folder. I've even searched my PC but cannot find those Wav files.
Any input is appreciated.
troymail
Silent Key
#2
When I do backups, after starting the app, I go to Tab B (BACKUP) and press the BACKUP button.
Once that completes, I go to Tab D (EXPORT) and click the Search button and then the Export All File button to save the files to a folder on my desktop.
After the export above, to remove the "hidden" copies of the files, I go to the Unication backup folder
C:\ProgramData\Unication
and then delete the folder
MessageBackup
cd rmdir /s MessageBackup
KR7CQ
Phoenix
#3
MessageBackup
Thanks. The key for me was deleting the folders....then it would backup.
