mikeformha
- Joined
- Aug 4, 2007
- Messages
- 6
Hi all, great forum.
I'm new here so I'm gonna start off with this...
Call me hair brained but...
I'm contemplating using a steel building as a reflector for my home made horizontally polarized 1/2 wave FM antenna.
It's orientated correctly for receiving the signals I want and blocking the signals I don't want (near by FM transmitter that over runs the band). So instead of mounting a typical antenna on top the building and exposing it to direct waves from that big bad transmitter I don't want stomping the band, mount it over the side about 20' up leaving at least 10' above it to the roof line. I'm guessing that a spacing of 1', 11 inches would be the standard spacing for a resonant reflector...
I was wondering if anyone here could tell me if the reflector for 98 mhz would have to be of the resonant type, or if, in my case, you have an area that is very large (30' high X 300'wide), would suffice as a "planar" style reflector, and whether or not that reflector spacing still holds true with a planar design.
I'm gonna try this soon but hopefully someone will stop me before I put a hole through a perfectly good building.
Any thoughts on this topic would be greatly appreciated.
Thanks,
Mike
Thanks,
Mike
