Methodist Aircare
Sanscanman
N5WRF
Acworth, GA
Good Afternoon,
I have been hearing tone outs and flight info on 151.5050 They identify the channel as "flight guard". there are two different PL's that I have identified so far. DCS 115 appears to be Air Care 1 based in San Antonio and DCS 054 appears to be Air Care 4 based in Seguin. There might be other PL's, but those are the only two i have come across so far. If anyone else has a chance to listen to this freq and post their findings here I will compile a list and submit it to the database.
W3DMV
Gettysburg, Pa
Can't help much since I'm out of range. Med choppers here
change so often it's like a full time job just to keep up.
If you have not looked at the list in the database, you might
have a peek.. Looks like 50-60 lin the list that could help
including several on 151.505
Listed under "Texas" > "medovac"
Good luck
NC5267
San Antonio
Haven't heard anything so far but I have noticed on the TXMED 1 channel 155.340 have heard the Airlife Dispatcher as well as another Air Med companies dispatch using this interop channel for what sounds like daily ops type stuff. The Airlife dispatcher has the standard 156.7 PL on the TX side and the other Air Med company is using 127.3.
