Please provide the citation for this, as the only sources found with Mexico RF changes, do not mention 440-450
That article talks about changes to those allocations. It may not have addressed allocations that have been in place for a long time.
The most recent National Frequency Allocation Table ("
Cuadro Nacional de Atribución de Frecuencias", or "
CNAF") I could find, from late last year, shows 440-450 MHz allocated to mobile (excluding aeronautical mobile - "
móvil, salvo móvil aeronáutico") and radiolocation ("
radiolocalización") services. The Mexican allocations are in the "MÉXICO MHz" column below:
This is, more or less, the same as it was in 1999. In 1999, 440-450 MHz was allocated to fixed ("
fijo") and land mobile ("
móvil terrestre") services. Again, the "MÉXICO MHz" column below shows this allocation:
Sometime before 1999, Mexico took the 440-450 MHz range away from radio amateurs, leaving amateurs with just the 430-440 MHz range. Even with this, I remember hearing some amateur repeaters operating (illegally, apparently) from Mexico in the 440-450 MHz range in the early 2000s, when I could get amateur permits from the SCT office in Mexicali.
