Bummer......I some switches don't easily give you the frequency range and I did see what you mean from info on one switch....I just didn't know if instead of switching between 2 antennas to one radio, I would use it to switch the antenna feed from one radio or the other.
Should I give up or do is this concept ok IF there is no frequency issue? Should I spend the time and see if there may be a switch that will cover
I just realized...I've kind of cross posted....when thinking about my situation:
Think I'm gonna try this
TW-102 2 Position Coaxial Switch It does state in the questions:
"This coaxial switch can be used reversely to connect one antenna to two radios, allowing you to switch between radios using the same antenna. According to the product description, this switch has a frequency range of DC-1000MHz and impedance of 50 Ohm. Multiple customers have confirmed that this switch can be used to connect one antenna to two radios."
Freq coverage is fine.....guess I'll check it out!
Unless anyone has a better suggestion! Thanks all!
