Speaking of going off on tangents...
I put a couple dabs of white lithium grease on the turns counter gears and then wiped off the excess.
And, I sprayed a couple spritzes of dry teflon lube into the bearings at either end of the roller inductor shaft. I put no lube on the roller wheel.
I also sprayed a couple spritzes of Deoxit D5 on the switch contacts and worked the switch back and forth several times.
Subjectively, the inductor knob seems to turn easier. With some effort, I can turn the inductor knob using just the finger hole on the knob. Definitely doesn't turn as easy as the rotary encoder tuning knobs on my radios, but it seems to turn easier than when I first got the tuner.
For those wondering, this tuner uses what I understand is called a "slinky" style roller inductor. There's a coil of stiff wire that is held in place at 0, 90, 180, and 270 degrees around the coil by what looks like circuit board material that has been notched to maintain the spacing of the coil. There's a shaft running through the axis of the coil with a roller attached to an arm so that the roller rolls along the inside of the coil. The coil does not move or deform as the roller moves through it.
Granted, being an MFJ product, it's built down to a price. MFJ might claim that it's a "3 kW tuner", but I know that I will never run that much power through it. I tried it yesterday evening with my 80-40-20 fan dipole and quickly got a tuning solution on all three bands using 100 watts on RTTY.
Finally, in typical MFJ fashion, the tuner had a rattle when I first got it. I took the cover off and found a loose screw. Upon further examination, I determined that the screw came from one of the brackets holding the inductor to the chassis. The nut for the other end of the screw was nowhere to be found. I obtained a replacement nut and reinstalled the screw. I snugged up the other fasteners on the inductor while I was at it.
