MIC recomendation
zzdiesel
Kennett / Dunklin Co, Mo.
I bought a cheap Super Star DM-507-4 for my Galaxy DX 98VHP. Everyone says it sounds real good on Ch 19 radio checks. The other channels are dead around here.
JayMojave
Mojave Ca
Hello Friskidog: I use a Astatic 636L noise cancelling mic on my Stryker 955 and get good audio reports on both AM and SSB modes. Keep the stock mic in the glove compartment as a spare. Always good to have a spare mic on hand.
Jay in the Great Mojave Desert
Minden
I am using a Barjan Diesel Noise canceling microphone with excellent reports on my Galaxy 979. About 21.00. total cost. Following is just FYI...Barjan Products. 7800 51st st, Rock Island, IL 61201. also available on E-Bay.
Retroradio
Ontario
I run Astatic pre-amplified mics on everything, base or mobile. I can't say how it will work on your Galaxy but I am very big fan of them. Anyone run an Astatic on a Galaxy for a quick review?
BBB007
You may get away with a power mic since the cab noise is low, unless you ride with the windows down a lot. Power mics will bring in more ambient background noise from the cab. Power mics typically utilize a 9 VDC battery to supply power to the processor in the mic.
Since the Galaxy 979 doesn't offer reverb, I may suggest an RF Limited 2018 Extreme Echo mic if you can find one. Your audio will be much fuller than the stock mic as long as you don't turn all the knobs to the right. I put some paint marks at the timing controls if they get bumped or tape over the adjustment knobs once I've set them so they don't change as I handle the mic.
I tend to like hearing a smidgen of reverb on the transmit side. Notice I did not say echo, I despise echo. These mics can have the processor turned way down and still offer a perceived louder than non-reverb transmission with a small amount of reverb present in the AM transmit mode. I do not run any reverb processing in SSB mode (although some well known Hams do at very light and fast timing levels without issue)
Nice write up on the 2018 by CbRadioMagazine:
http://cbradiomagazine.com/Micropho...2018/RF Limited 2018 Turbo with talkback.html
