michigan programming/ 536/436
I900D658
ontario
#1
gents can anyone tell me the best way to program a favorites list for sanilac county, stclair county, andl lapeer county with out using the whole michigan public safety system
Fightin\' River, Michigan
#4
Append the MPSCS departments/talkgroups you want to monitor to your Favorites List.
Delete or Avoid any sites which you don't need, or use Location Controls to not scan them.
(In most cases, 2-5 sites will cover a county.)
iMONITOR
MACOMB, MI.
#5
The fastest way to get started, check your manual for how to use the Zip Code method of programming, then set your radius distance to 5 miles. Then select/deselect the appropriate Services you want to monitor.
iMONITOR
MACOMB, MI.
#7
