Micro sd card upgrade question for sds200
bravo14
Polk County FL
crippledchicken
Butler County MO
Good deal, cause that's what I bought and put in it didn't want to say that til I found out if it was a step upward or not! :ROFLMAO:
crippledchicken
Butler County MO
I believe sds200 will hold a max of 32gig card. I'm not sure if there is a certain speed or class it takes.
I was thinking maybe it should be a class 10 but, I thought the one I bought said it was a class 3 somewhere but not positive.
bravo14
Polk County FL
jonwienke
More Info Coming Soon!
VA
The most important thing is to get a "High Endurance" type of card, at least if you have Replay turned on (which writes to the card with every transmission received). Flash memory has a finite number of writes before it fails, but the high endurance cards can handle a lot more writes before failing.
