HP-1: micro sd replacement ???
llwade
Chillicothe, IL
Home Patrol 1, wanting to purchase extra SD.
As long as I purchase a " MICRO SD " are there limits to which one will work?
2nd Question, any problem increasing SD capacity to 32 GB ?
llwade
Chillicothe, IL
what is the difference between class 4 & class 10 SDs
will they both work ?
mully95
Anderson SC
MULLY95 ..... thank you for the post. I will check it out shortly
I believe you want a class 10 non UHS-1 card. UHS cards are designed for devices that support UHS. I'm not sure if the these scanners will support UHS so I just wanted to throw that out there.
mully95
Anderson SC
Yeah they will both work but
There is four speed classes of 2, 4, 6, 10.
2 being the slowest and 10 the fastest.
I'm going with a class 10 (in which I already had)
llwade
Chillicothe, IL
using the same brand as what is in Home Patrol 1 scanner ( Toshiba )
32 GB memory card class 4.......... $ 19.99
32 GB memory card class 10......... $ 69.99 ( uhs-1 )
OUCH ! how much difference will I see with a class 10
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Anything below a Class 10 will result in things like the scanner taking time to respond to your keypresses, slower transfer of recorded data, slower upload/download from Sentinel of your database updates and favorites lists, etc.
rcool101
Eastern Ohio
I just bought one of these 3 weeks ago...... $ 17.89... on ebay for my tablet. Personally I think 32GB is overkill. I got an 8GB for my backups. Its double and more than enough. To each his own
SanDisk 32GB Ultra Micro SD HC Class 10
mully95
Anderson SC
Well I thought it was overkill as well BUT read all of this thread. Unless you're not in to recording then it would be overkill. The fact that I can record while I'm asleep or busy doing other things that is impossible to listen to the scanner is a added bonus to this scanner. Like taking a shower for instance. lol
The more memory you have the longer you can record.
http://forums.radioreference.com/uniden-tavern/309684-4gb-32gb-micro-card.html
llwade
Chillicothe, IL
need some help on which micro SD to purchase
will this SD work OK ?
SanDisk 32GB UHI-1/class 10 micro SDHC memory card $ 15.99
Voyager
That's what I am using, but mine is a SanDisk Ultra.
dave3825
Suffolk County NY
What came with my 436 is a 4 gb class 4. Uniden designed the radio to work with a class 4. You say anything under a class 10 will result in slowness.
Did you mean anything under a class 4 would be slower (being that's whats in the radio) or do you have actual documentation stating that anything less then a class 10 will result in poor performance in these radios?
Just curious.
