SDS100/SDS200: Micro USB port
akuter
Eau Claire, Wisconsin
I unplug/plug from the Micro USB port for programing. I'm thinking I may have damaged the soldering inside. Do I to send it in for repair? Same for my G5. Any other ports I can use for programing.
Ubbe
Stockholm, Sweden
You can always take out the SD card and use in a SD card reader. It's not as easy doing it to a SDS100 as a SDS200 but I wouldn't expect that the need to program comes that often. As you mention micro port it has to be the SDS200 so super simple to take out and insert the SD card.
If you get that USB micro port fixed then I would suggest to use a magnetic USB tip that stays permanently in the connector and you only pull the cable and it detaches from its magnetic connector.
/Ubbe
D31245
FN42
As @Ubbe suggested, this is what I am using on my G5. So far, it is working out great with no issues. Note: it is a 5-Pin adapter which matches the G5. Not sure about the Uniden SDS series as I don't own one nor know the specs.
RandyKuff
Lorain, Ohio
Which scanner you using...
The 200 uses the "Micro USB on the front...
The 100 uses the "Mini USB on the side not the micro...
Nasby
Ohio
Correct. I don’t see a mini USB magnetic insert on the amazon links so the products won’t work on the SDS100 for programming.
