Microphoe coversion
airboss20
Horseheads, NY
I would like to use a GE desk microphone I have for a Vertex FTL-7011. I have figured out the correct wiring for PTT, Ground and Monitor, But I am having difficulty with the Mic audio. The GE mic lists Mic Hi and Mic Low, where the Vertex only lists Mic In. Neither of these will pass audio. Does anyone have experience with this issue?
cmdrwill
So Cali
Some 'GE' mics require carbon mic bias. Most of these were made by Shure.
GE mic low is ground in most cases, Mic Hi is the mic output Vertex Mic input.
airboss20
Horseheads, NY
I was able to do some experimenting and found that if I apply the 5v output at the radio mic connector to the MIC Hi of the microphone, and then MIC LOW from microphone to the MIC IN resulted in proper function of the microphone.
